internally balanced flywheel
Old Mar 7, 2006 | 11:39 PM
moserman's Avatar
question for yas, would an internally balanced flywheel from the 3rd gen tpi's work for an internally balanced stroker motor i just bought or is it better to send mine out to get machined???? need your input!
Old Mar 8, 2006 | 04:12 AM
sssalah's Avatar
Re: internally balanced flywheel
For an internally balanced rotating assembly, a neutral balance flywheel/flexplate is needed. Not sure if the flywheel would work but a flexplate is the same. The counter weight on the stock flywheel could be yanked to make it neutral.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
karpetcm
Sep 29, 2015 10:08 AM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
