Intake restriction on 383
Old May 31, 2013 | 06:14 AM
PA94Z's Avatar
I have been looking through some of my data logs working on another bug. I noticed my MAP readings are pretty bad at WOT. I am getting 3 - 4" of vacuum throughout the rpm range. The air intake has a huge Amsoil cone filter running into 3.5" pipe with 1 90 degree bend. Still running a MAF, 58mm throttle body, and a ported LT1 intake. Lets hear some input..
Old May 31, 2013 | 08:10 PM
white97T/A's Avatar
Re: Intake restriction on 383
What do you mean by bad readings?
Old May 31, 2013 | 10:00 PM
97WS6SCharged's Avatar
A NA 383 shouldn't move that much air. I'd verify that the TB is opening all the way as my first step.
Old May 31, 2013 | 10:32 PM
PA94Z's Avatar
TB opens all the way.
By bad I meant the vacuum reading in the manifold should be between 1 - 1.5" at WOT. My readings are 3 - 4"..
I took a look at a log I made last year just after getting the motor running - the one and only WOT run I did with the LS1 lid I had previous. Vacuum readings were 1 - 2". So the air intake piping/filter is my restriction. I am going to try a K&N to see if the Amsoil filter is the issue.
Can't fit a LS1 lid with the stand up radiator I put in over the winter. I didn't think I'd lose that much with the intake.
Old Jun 19, 2013 | 04:17 PM
PA94Z's Avatar
Well I tried a K&N filter with no change. After that I installed 4" elbow, this helped a little but I am still seeing 2.5 - 3" of vacuum. I ordered a cowl hood so I can fit a LS1 lid back on the motor.
Drtryder
Apr 22, 2015 04:17 PM
transam_388
Mar 15, 2015 11:53 AM
mritter1965
Exhaust System
Feb 15, 2015 07:31 AM
MadMav
Feb 6, 2015 11:02 PM
