intake question
Old Jan 31, 2007 | 12:23 AM
custom95's Avatar
intake question
Just wondering if there are differences between a 94 corvette lt1 intake and fuel rails compared to 94/95 camaro lt1. I've been told that in order to use a camaro engine harness for my motor swap I will have to switch the intake and fuelrails/injectors to camaro spec. I know that the corvette injectors should be fine, but the only reason I think that this might be neccesary is due to the location of fuel lines and maybe the harness connections to the injectors. Any thoughts? If at all possible, I would rather not spend any more $ than I have to, so if the are minimal differences that I can modify easily I would rather keep the corvette intake and fuel rails as opposed to buying camaro parts.
thanks
Old Jan 31, 2007 | 01:35 PM
Chris 96 WS6's Avatar
No difference in the intake. The difference in the fuel rail is where the lines connect. Its at the front on a Corvette, in the rear on an f-body.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
mikey4play
Mar 15, 2015 11:45 AM
LT14LIFE
Feb 9, 2015 09:35 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
