Intake not fitting
Are you using guide studs? Is the oil sender unit and mount contacting the back of the intake preventing you from putting it in?
Never heard of drilling the holes out but hey could be something else to add to the bag o' tricks.
Is your issue fitment or ligning the holes up?
It dropped in perfectly, didn't mess up the RTV and I thought I was almost done. Got one side in finger tight and the other side would start and then gall. So I looked a bit and it appears to be a 1/16" off or so.
Well I was going to try and grind out one side with a dremel but then I thought that wouldnt that make the intake sit wrong? This is driving me crazy here, if I drill all the holes out, how can I be sure its sitting in the right place?
stockssn2o
May 25, 2015 08:54 AM
CARiD
Jan 27, 2015 06:27 AM
