intake manifold repair - will there be fuel in fuel lines?
im about to attempt to fix my leak.. Will there be fuel in the lines? car has been sitting for 3 days.
Haynes manual says release pressure from fuel lines.
ALso says drain coolant.... really?
thanks
thanks
there shouldnt be any pressure but just in case, release the pressure. Just press in the center of the valve on the fuel line on the back of the intake. Very easy to do. They say to drain some antifreeze because of the line running through the throttle body.
CARiD
01-27-2015 06:27 AM
07-04-2005 05:00 PM
