intake manifold leak...
Old Feb 27, 2004 | 10:30 PM
sabre81's Avatar
Im thinking of tackling this job. im thinking maybe the leak is reducing the octane in my fuel, maybe causing a little knock retard. Wondering how long it takes roughly. What are the going prices for set of gaskets. Also what is the price for some valve cover gaskets?
thanks
Old Feb 27, 2004 | 10:57 PM
97WS6SCharged's Avatar
Definately get a mirror and flashlight and check the manifold before you start replacing the gaskets. My felpro intake set was $20 bucks, I believe the valve cover gaskets are about the same price. Luckily my problem wasn't the intake, it was the fuel pressure regulator.
Old Feb 27, 2004 | 11:00 PM
sabre81's Avatar
well i figured with 120000 miles on my 94 it coudl use some new seals anyway.
Old Feb 27, 2004 | 11:22 PM
OBE1 95Z28's Avatar
The stock valve cover gaskets are nice pieces; I doubt you need to replace them. Most guys on the board have had the best luck using stock GM intake gaskets. It's not the gaskets that leak, the gaskets only run down the sides on the intake, it's that fact that only RTV seals the front and the back of the intake!
Old Feb 27, 2004 | 11:26 PM
If you're going to replace them, I'd go with the coper RTV. That stuff never leaks.
Old Feb 27, 2004 | 11:28 PM
OBE1 95Z28's Avatar
Here's a link to a fix write-up:
http://www.geocities.com/MotorCity/Downs/4013/ol.html
Old Feb 28, 2004 | 01:43 AM
ram air camaro's Avatar
intake gasket
i just finished mine yesterday! call summit and order your felpro gasket part# fpp-1284 it also comes with black rtv high temp silicone for cheap price of $19.99 , and then buy your valve cover gaskets at auto zone for about $14.00 bucks.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
