intake manifold bolts...
Old Jul 21, 2004 | 11:45 AM
atljar's Avatar
A guy at school here knew my car, had a friend who needed his 95 TA put back together. I guess the car has been apart for a few years and hes clueless as to how to get it all back together.
Anyways, i went out there last night and the entire car is in boxes, all mixed up bolts, parts etc. What a mess.
Anyways, i found the intake studs, but couldnt find the bolts. Only thing i found were some longer bolts that had 1/2 thick washers on them. Anyone ever seen anything like this? They almost looked like the hub bolt washer, but were fit the intake manifold bolts.
Just wondering if those were ever used stock, or if someone had pulled the intake before and used those instead.
Also, why would you pull the motor, build it, and then put JUST THE BLOCK in the car. Heads and intake laying on the ground waiting to go in??????????? AHHHHH, making life hard.
Old Jul 21, 2004 | 12:33 PM
RE AND CHERYL's Avatar
Re: intake manifold bolts...
I just installed my headers and the stock exhaust manifold bolts had washers like you describe.
The only reason I can think of for installing the block first is there would be more room to work. After installing the block, then drop in the heads and intake.
Have fun putting the project back together.
Old Jul 21, 2004 | 12:35 PM
Those bolts with the thick washers are the 4 outside bolts on the stock exhaust manifolds.
Old Jul 21, 2004 | 05:21 PM
atljar's Avatar
lol, exhaust manifold bolts eh?
No harm I suppose using them correct? Both screwing into the head. The threads matched and i checked to make sure they didnt bottom out.
Shrug, wonder where his intake bolts are....
Old Jul 21, 2004 | 11:21 PM
atljar's Avatar
oh the other thing...there were 7 of them, not 4?
Old Jul 21, 2004 | 11:40 PM
jchevy's Avatar
Im pretty sure the exhaust manifold bolts were a smaller diameter than the Intake manifold. I also think all my manifold bolts had the thick washers.
If the bolts torqued fine i wouldnt worry about it
Old Jul 21, 2004 | 11:43 PM
Nah, just about everything that bolts to the head is 3/8-16 thread.
Old Jul 22, 2004 | 12:07 AM
atljar's Avatar
Yes everything was TQ sequenced according to my service manuals, so thats good. Im not too worried about it, the intake is holding and the headers are on there with the supplied bolts. All is well i guess.
Thanks everyone
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
