Intake Mainfold Gasket - GM or Felpro? Permatext Right Stuff?
Old Apr 16, 2011 | 04:19 PM
Wilson's Avatar
Smile Intake Mainfold Gasket - GM or Felpro? Permatext Right Stuff?
Time to do the dreaded intake manifold leak repair again (3rd times the charm) after a good 10yrs.
Anyone try the Felpro gasket instead of the GM?
FEL-PRO Part # MS95580 $13.11
http://www.rockauto.com/catalog/moreinfo.php?pk=125666
Looks like the Felpro kit gives the TB, EGR & Intake MF gaskets, new o-rings for injectors and sealant.
Also, the searches online it seems that there is a new Permatex sealant.
Permatex The Right Stuff Gasket Maker is the new way to go.
This could very well be my last intake manifold repair for another 10yrs?
Old Apr 16, 2011 | 05:42 PM
Kevin Blown 95 TA's Avatar
Re: Intake Mainfold Gasket - GM or Felpro? Permatext Right Stuff?
I can't use intake gaskets with silicone beads because I use the LT4 performance gaskets, so I spray my gaskets with Coppercoat and then use Right Stuff for the China walls. It's a good combination for that type of gasket.
Old Apr 16, 2011 | 05:58 PM
96capricemgr's Avatar
I like that kit and the silicon in the kit works just fine.
I do not like the blue Felpro gaskets as I several friends and myself all had them delaminate the bead came loose and sucked into the port, mine an LT1 one an SBC and another a BBC.
Right Stuff is not that new, been around awhile and is a quality product.
Old Apr 16, 2011 | 06:19 PM
ACE1252's Avatar
I personally prefer GM LT1 intake gaskets. I don't know what type Autozone stocks, but I did pickup a set of them and they were no where near the quality of the GM units. The right stuff is very good.
Old Apr 17, 2011 | 08:52 AM
RamAir95TA's Avatar
I like the GM gaskets as well over the Felpros. They are much more robust.
Old Apr 17, 2011 | 09:44 AM
I like the GM ones too but the Felpro kit with the grey gaskets works just fine too.
Old Apr 18, 2011 | 09:18 AM
95zsean's Avatar
Victor-Reinz, they make them for GM and they are cheaper than the GM ones. You can get them at NAPA, I'll check for a part # if you want? I have it at home....
I also use a chisel to make a line in the "great wall" front and back, so the Copper silicone has something to stick to.... I did this my 3rd time and have not had to do it again....
Good Luck
Old Apr 18, 2011 | 10:46 PM
twistedbowtie's Avatar
i used the felpro worked great for me
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Snoman73
Nov 17, 2014 07:22 PM
