Intake Gasket for Trick Flow Heads
Old Feb 9, 2012 | 09:14 AM
Mystery Bird's Avatar
I was using the Felpro 1284 for my ported stockers but they don't line up great with the Trick Flows I have now. What's everyone using for their Trick Flows?
Old Feb 9, 2012 | 01:02 PM
V8 LifeStyle's Avatar
Re: Intake Gasket for Trick Flow Heads
I just installed my trick flow heads like a week ago and I part number 1074 they are performance gaskets by felpro, this is what trick flow told me to use. its like 48 buck each.
Old Feb 9, 2012 | 01:19 PM
96capricemgr's Avatar
So you used head gaskets you paid too much for as intake gaskets? They are under $37 on RockAuto. As thick as they are they should be reserved for zero decked blocks.
Far as INTAKE gaskets my opinion would be to run a factory type gasket(from GM or Victor Rienz) would be easily trimmed to fit since they are just plastic, no steel core.
Old Feb 9, 2012 | 02:17 PM
Guess I'll just do so trimming then, thanks.
Old Feb 9, 2012 | 02:35 PM
I am sure you could get away with say an LT4 gasket but the LT1 stuff is as easy to get ahold of as the local parts store.
Old Feb 9, 2012 | 04:01 PM
Funny you should mention that. I just found a set of LT4's (12367777) in the for sale section and decided to give those a try.
Old Feb 9, 2012 | 04:58 PM
My bad I understood you wanted the head gaskets. Im using the GM gasket for the intake and it lines up fine.
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
