Which Intake Gasket Is Best?
Old Mar 3, 2006 | 08:27 PM
1quickTA's Avatar
Alright, hopefully this is my last post before this cam swap is done! I am about to put my intake back on and I was just wondering which gasket set I should use because I have two. One set came with my cam swap gasket set from Combination Motorsports, and it is a Fel-Pro, more of a cardboard type gasket with blue rings around the ports. The other set I have from a while back when I bought a set cuz I needed a TB gasket and these are Fel-Pro but a metallic compound. Which would be best to use??? Also, I have researched a bit and it seems like most people say to not use any sealer on the gaskets - is this correct? Thanks AGAIN everyone
Old Mar 3, 2006 | 08:38 PM
SS RRR's Avatar
Re: Which Intake Gasket Is Best?
Either gasket will do fine as long as they aren't blocking any part of the intake port. There is absolutely no reason to use sealant except at the front and rear of the block.
Old Mar 3, 2006 | 08:50 PM
1quickTA's Avatar
They both block the pass. side rear most runner a little bit That was an issue last time I put my intake on as well. So which would you use if you had to pick?
Old Mar 3, 2006 | 10:09 PM
Josh'95Z28conv's Avatar
Ive always used the graphite type.
Old Mar 4, 2006 | 12:03 AM
Joe B's Avatar
Use a dremmel tool (or similar)with a small grinding bit if you have access to one, and open the gasket up a bit where your saying it needs it... thats a pretty big thing to ignore considering it's a 2 minute fix
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
