Installing Stall Converter
Old May 22, 2003 | 11:33 AM
GeneralZ's Avatar
Question Installing Stall Converter
I just got my SLP 2800 in the mail today. I have installed a couple trannys before, but they were in full size trucks. Is there any problems i can expect to run into while doing this?
Do you guys have any tips for the job? Also, how much fluid should i put in the coverter?
Thanks in advance
-Jon-
Old May 22, 2003 | 10:35 PM
Pro Built Automatics's Avatar
Put in one quart in the TC and then before you bolt up the TC to the flexplate, check the clearence between the TC and flexplate at the mounting pads. It should be between .090 & .125, if more it will need to reduced with machined type flat washers. All three washers must be the same "exact" thickness if this is needed.
marine1bird
10
Jan 25, 2015 12:02 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
squarehead
Nov 21, 2014 08:02 PM
mysticslp2002
Jul 29, 2002 02:03 PM
