Installing new pickup on new oil pump...
Old Mar 30, 2004 | 03:37 PM
96 WS6's Avatar
I can't get the damn thing in for the life of me. I put the pickup in the freezer for a couple days and heated the oil pump with a torch. Still no luck. The fit is so tight... are there any tricks to getting that pickup in.
Old Mar 30, 2004 | 04:30 PM
HesterZ28's Avatar
Thats odd I put mine in the freezer for 4 hours and it went right in. lube it with motor oil. Be sure to spot weld the pickup on after it slides in and before installation.
Old Mar 30, 2004 | 10:37 PM
my94blackz's Avatar
Take a line wrench put it over the pickup then take a hammer and tap it, be patient.
Old Mar 30, 2004 | 11:13 PM
Spinner's Avatar
Sand it down a bit if necessary. Weld it in there. Mine wasn't welded, and it costed me my motor.
Old Mar 30, 2004 | 11:17 PM
They make a tool to install them, but I usually use the wrench method since that is all I have. The one I just recently did, took a lot of persuasion. The trick to getting it started is to line it up as straight as possible.
Old Mar 31, 2004 | 01:56 AM
96 WS6's Avatar
I ended up putting the pickup in a vice and tapping the pump onto it with a hammer and a block of metal.
Thanks to those that answered... it seems like putting a spot weld or two is good insurance to have the pickup stay on. I think it's kind of dumb that they made the pickup a press fit on a part that's constantly going to be heat cycling. Oh well...
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
