Installing Motor Mounts
Old Feb 10, 2004 | 09:22 AM
EviLBoX's Avatar
I've got a set of polyurethane motor mounts ready to install, but I have a question. I know you need to drill out the rivets on the driver's side mount, but how did you guys get a drill in there? There's hardly any room. I was thinking if I couldn't get to that mount would it be okay to only change the passenger side? That's the side the engine torques to anyway, I'm just trying to prevent my y-pipe from banging the undercarriage of my car.
Thanks.
Old Feb 10, 2004 | 09:27 AM
rocmemphis's Avatar
You have to unbolt and pull out the entire mount. Not really difficult but not fun either
Old Feb 10, 2004 | 09:51 AM
carlos64030's Avatar
You aren't trying to do this with the mounts still attached to the block and the frame are you?
Old Feb 10, 2004 | 09:54 AM
EviLBoX's Avatar
No no, I haven't even started yet. I just read a few posts in the past and remember someone mentioning having to drill out the old rivets, then use the supplied bolts to put in the new mount.
Old Feb 10, 2004 | 10:18 AM
teke184's Avatar
i just finished replacing the mounts on my LS1...not fun
it took me the better part of 10 hours, not including breaks!
you have to really jack the motor up to remove the mounts (least on the ls1...can't be much diff on the LT1).
when you have the mounts out, either grind off the head of the rivit and use a punch to drive it out, or you can use a pointed punch to put a dimple in the middle of the rivet and then drill it out.
grinding is easier.
i did both mounts because of the same problem you are having. havn't driven it yet but i fired it and the engine barely moves when revved up.
worth the effort.
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
Jason Short
Jan 19, 2015 06:34 PM
