Installing Intake Manifold
Old Feb 9, 2006 | 07:05 PM
Onebadlt1's Avatar
is it true that while installing your intake manifold.. if u tighten all the bolts on one side then all the bolts on the otherside.. it creates a problem with the gasket? that it may cause the car to leak coolant into the oil?
Old Feb 9, 2006 | 08:24 PM
Cmr0z28's Avatar
Re: Installing Intake Manifold
Looking at the intake manifold from the front
6 -- 8
5 -- 7
1 -- 2
4 -- 3
11 -- 9
12 -- 10
That's the proper tightening sequence.
Old Feb 9, 2006 | 11:24 PM
Old Feb 9, 2006 | 11:25 PM
Cmr0z28's Avatar
Showoff! I was gonna scan mine but I'm too lazy.
Old Feb 9, 2006 | 11:28 PM
Easier to describe by a pic. It was already on my website.
Old Feb 10, 2006 | 03:34 AM
MTL_Z28's Avatar
If I'm not mistaken there are no coolant passages in the intake manifold, there's no way that it would cause coolant to end up in your oil. Improper installation of the manifold might cause a vacuum leak, but not coolant in the oil.
Old Feb 10, 2006 | 06:58 AM
94_Z28_guy's Avatar
Improper install could and most likely will cause an oil leak too. Tighten in the proper sequence.
Old Feb 10, 2006 | 09:08 AM
Onebadlt1's Avatar
Thanks everyone for your help
Noer
Feb 28, 2015 11:29 AM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
