CamaroZ28.Com Message Board
-   -   Installing headers on a 97 camaro (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/installing-headers-97-camaro-866250/)
my1994z28 Jun 7, 2012 09:36 PM
I am hoping this is the correct section for this question...This is my first completely "stock" lt1 camaro,I am installing ceramic coated pacesetter long tube headers,I am removing the cats,and emission componets...My question is where do I relocate the O2 sensors to?I have not received the headers yet,so i dont know if they have provisions for the 4 O2 sensors.I know that they have 2 locations for them,but i am unsure about the other 2.Any help or suggestions is appreciated.
lt11997 Jun 7, 2012 09:48 PM
Re: Installing headers on a 97 camaro
You don't use the rear ones, you'll have to get 02 simulaters or tune them out of the pcm. The front 02s go in the headers and you'll need to buy wire extension harness for both of them. Some people cut the factory harness and splice in extra wire but I don't recommend cutting up the factory harness if it isn't necessary.
my1994z28 Jun 7, 2012 10:45 PM
Ok,thanks...Are the square plug or flat plug considered the rear o2s?Also what company can i get the simulators from?
RamAir95TA Jun 8, 2012 05:17 AM
Rear O2s use 4-pin square connectors.
Just about any site sponsor can get simms for you.
6SpdLT1Z Jun 8, 2012 10:49 AM
I put Pacesetter LTs on my '97 SS a couple years ago.
You said you aren't running cats, why would you keep the rear o2 sensors? Tune them out or buy o2 sims. As Joe said, the rear o2's use square 4-pin connectors. Fronts use flat 4-pin connectors.
As far as purchasing o2 simms, look at our site sponsors. Here's a link for what you're looking for. You'll need 2. Speed Inc - Pure Power
Personally, I'd use that money and spend a little more on a mail order tune and have the rear o2's tuned out.
Here's a couple threads on my setup:
https://www.camaroz28.com/forums/lt1...s-list-735320/
https://www.camaroz28.com/forums/lt1...1470-a-731659/
https://www.camaroz28.com/forums/lt1...nsions-731199/
my1994z28 Jun 8, 2012 05:17 PM
ok thanks guys,I am going to have them tuned out..;)
CamaroBoy96Z28 Jun 9, 2012 08:14 PM
Do that. I had mine tuned out. Header swap is not too bad. I did it on my 96 and a buddy's 94. Undo the motor mounts and jack up the motor as needed. I think I did both from the bottom...its been 9 years so I don't remember exactly what I did.
my1994z28 Jun 10, 2012 10:02 PM
I have both manifolds,emission parts,y-pipe,etc removed..Just waiting on UPS to bring the headers and y-pipe tomorrow...:D
mrcallison Jun 28, 2012 11:54 AM
Did you use 02 sims or tuning? I currently dont have my 02 sensors hooked up
RamAir95TA Jun 28, 2012 01:24 PM
O2 simms are for deleting the rear O2s. The front O2s are required for fuel trim from the PCM so they need to be functional.
my1994z28 Jun 28, 2012 03:16 PM
Ended up getting the rears deleted out...
