installing headers
Old May 17, 2004 | 01:35 PM
MeanZ687's Avatar
installing headers
I bought jethot headers and i wanted to know if you have to jack up the engine or anything to put them on and can i do it like it is or should i get it done by a shop?
Old May 17, 2004 | 02:56 PM
1996 | Z28 SS's Avatar
If you know how to do it and you have the tools.. then do it yourself and save the 300ish dollars from having someone else do it. Much more gratifying to do it yourself IMO
About jacking up the motor.. I've heard some can get away without having to. However, for the most part of what I've read.. you usually have to raise the motor a little.
Old May 19, 2004 | 02:52 PM
MeanZ687's Avatar
about how long does it take to install just the headers probably?
Old May 19, 2004 | 03:49 PM
nitropatch's Avatar
on my same header install i had to jack the passenger side up a little bit
Old May 19, 2004 | 07:34 PM
25thBird's Avatar
I had to jack the passenger side just a little and made the passenger side install a lot easier. Just support your mottor on the oil pan and drop the motor mount ot raise the motor mount an inch or so. The header will slide in easily. I had a friend help me do this and had no problems lifting the motor.
Old May 19, 2004 | 09:06 PM
Kataklysm's Avatar
Header install time for a knowlegeable person should take a full days work with the right tools. Just make sure you got every wrench before you start and you should be alright.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
