Installing Coil
Installing Coil
When putting the bracket that holds the coil back on the head, should the coil be on top or should the piece under it be on top? Like here. When I took mine off, the coil was on top, but every other picture I have seen is like the one above. Or does it really matter?
Originally posted by besz28
should not matter,of course the battery gives the spark,and you can actually push the car to start with a dead battery.or it could be the opti
Also, you are wrong about 'push starting the car to start it with a dead battery'
I suggest you go try that sometime.. it won't.. [electric fuel pump for starters.. also the PCM, injectors, coil, opti, etc. need juice..]
That kind of stuff ended in the 70's
Henson071
May 4, 2015 12:23 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
