Installing 1.6rr's tomorrow, missing anything???
Old Jul 30, 2004 | 11:35 PM
jasons93z's Avatar
I have the lt4 springs/caps and proform 1.6rr's. What else do i need besides the tools. Assembly lube? Any other parts im forgetting? Thanks.
Old Jul 30, 2004 | 11:47 PM
Compstall's Avatar
Re: Installing 1.6rr's tomorrow, missing anything???
Doesn't sound like you're missing anything. Drop the rockers in a coffee can of oil tonight and they'll be nice and soaked by the time you install them.
Old Jul 30, 2004 | 11:50 PM
jasons93z's Avatar
Do i just use the old retainers? Should i replace the valve seals or leave them?
Old Jul 31, 2004 | 12:02 AM
Compstall's Avatar
Chenge out the valve stem seals. They're cheap; it only makes sense, you're in that far anyway.
Old Jul 31, 2004 | 12:07 AM
jasons93z's Avatar
Does autozone carry them. Im going there anyway for the assembly lube and the valve seals. Also, the much needed spring compressor. But i can keep the old retainers in, correct??
Old Jul 31, 2004 | 12:20 AM
jasons93z's Avatar
Also, any tips?
Old Jul 31, 2004 | 01:10 AM
Compstall's Avatar
Yep, Autozone should carry them. Sorry, I don't have any good tips to share. At the time I did the job, I have never touched the valvetrain on a V8. I did it the easiest way I thought I could do it without screwing anything up (cylinder to cylinder method, in order). So far I've got almost 10,000 miles on the engine since I did the rocker swap and haven't had to go back, so I feel I did SOMETHING right.
Old Jul 31, 2004 | 09:57 AM
Fuels94TA's Avatar
Dont forget a small magnet to remove the valve locks. I also recommend changing out the valve seal there are very cheap to get. I just replace a couple on my car from NAPA for $1.90 each. If you need any tips just search for shoebox site and I belive he might have a how to section.
Vinny
Deadbolt24
Jan 19, 2015 01:29 PM
Collector Car
Jan 5, 2015 10:58 AM
thenewkid
Nov 27, 2014 09:41 AM
ezcheeze15
Aug 26, 2002 01:28 PM
