Installed long tubes now both 02 sensors dont work?!?!?!?
I recently installed new hooker long tubes and mufflex y-pipe. I didnt have 02 extensions when I finished the install so I ran with them disconnected for a day or 2 until they arrived. Well once they did I connected everything up and the car runs like crap. Feels VERY sluggish and you can feel powering surging throughout the rpm band during normal acceleration. So I then bought brand new GM 02 sensors, installed those and this did nothing at all. Exact same problem still. So I then bought yet another set of 02 extensions thinking maybe a wire is bad. Installed those and still same problem. Now im starting to get aggrivated. I have checked that all wires are nowhere near the headers and are all in perfect condition all the way to the cars computer, I have done my best to ensure no exhaust leaks near sensors. I ran the car with a diagnoses program while driving and it informed me that both 02 sensors are failing. I then purchased a new OBD2 to OBD1 conversions PCM thinking maybe there was somehting wrong with my original tuned OBD2 computer. The new computer and tuning did nothing for me. SO now I just run in open-loop mode where it runs perfectly smooth. I need to figure out what is wrong can anyone help?
When I was running my OBD2 computer with 02's connected I was getting codes 0133 Bnk 1 Sens 1 02 slow repsonse, P1153 Bnk 2 control shifted lean, and P1133 Bnk 1 Sens 1 insufficient switching control shifted lean.
I do not know whats wrong and need to fix this problem. Any help is greatly appreciated.
Well I already stated that I have no burnt wires. But you did make a good point that maybe I did right before the install or sometime since then. I will look at all my fuses tomorrow when I can actually see. I just find it weird that BOTH sensors can be malfunctioning and a blown fuse could probably do that. With my luck though and all I have done so far I wont count on it being as easy as a fuse:-)
Anymore opinions?
Anymore opinions?
I was under the impression that you HAD to use O2 simulators in the back two O2's if you put in LT's in a '97. The rear O2's will not function properly with LT's. Does the OBD1 conversion get rid of the rear O2's all together?
I could be wrong.
Dan
I could be wrong.
Dan
Yes I have always been running rear 02 simulators, and now that i went with the OBD1 conversion it no longer uses the rear sensors anyway. I checked all fuses in my car all of them are fine
Alright, so anymore opinions im still clueless?
Jul 4, 2005 05:00 PM
