Installed 1.6 1418 COMP rockers
Old Aug 5, 2007 | 08:29 PM
canuck94z28's Avatar
Just finished install and went smoothly except air tube on pass.side wouldn,t come out so ended up moving it out of the way,but rockers cleared v/c,and first impressions ,this is a great mod as idle still sounds stk,bottom end improved,better pull thrumid range and better top end.This mod seems lot better than the 52tb i did last year and w/tuning by MADz28 the car isn,t running rich @high rpm.I will try to get some new times this month to see what kind of improvements the tune/rockers did and maybe install theVIG 2800 this fall and hopefull see high 12,s! What do you guys think,is it possible?THANKS.
Old Aug 6, 2007 | 05:06 PM
2000GTP's Avatar
If you do some weight reduction, you might be able to slip into the 12s.
Old Aug 6, 2007 | 08:20 PM
THANKS for the reply and i did have the car down to 3290 a couple years ago and the fact that w/me in it was 3420 i can easily do that again.I also have a SUMMIT c/o that isn,t installed yet and w/the work i do i can get down to 114 pds so ya i can easily get down the weight(lol).
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
Roadie
Feb 16, 2015 10:34 AM
