Install LTs while doing H/C?
Old Jul 23, 2005 | 05:25 PM
neil350's Avatar
I plan on doing heads cam, some time before I plan on replacing the fuel pump. Would it be easier to do Long tubes before or during h/c? It doesnt look that bad to intall while the heads are off, almost like they would just drop in place. Any input?
Old Jul 23, 2005 | 05:29 PM
Camarocracy's Avatar
Re: Install LTs while doing H/C?
I'd do them at the same time, why unbolt/rebolt the headers twice.
Old Jul 23, 2005 | 05:47 PM
ltwonz's Avatar
Do them at the same time you'll have the accesories out the the way already to make it eaiser.
Old Jul 23, 2005 | 05:54 PM
turbo_Z's Avatar
Took me maybe 20 minutes to install hooker LTs with the heads off but thats because I had been working on my car for FAR too many hours to think clearly.
Old Jul 23, 2005 | 07:21 PM
95RagtopTA's Avatar
I tried to do the same thing, heads/cam/LT's at same time. Driver's side was cake w/o the head on--was able to let the LT lay there, bolted on the head and then the LT. Problem was the Passanger side, even with the head off there wasn't a way to set the LT in place and still get to the bottem head bolts . I tried for hours and couldn't do it--ended up doing it the traditional way which was a huge PITA (had to jack the motor up, took forever). Good Luck!
Old Jul 24, 2005 | 01:42 AM
neil350's Avatar
Good point, what I'm wondering is, how bad would it be just to jack up the short block instead of an entire long block? I have seen guys upgrade to ported heads in cam only cars and both headers are left in place. So I mean with the heads off I imagine it would make it some what easier.
Neil
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
maybe2fast
Mar 16, 2015 11:59 AM
Bignasty85
Mar 3, 2015 04:05 PM
