Install complete
Old Jul 9, 2008 | 07:02 PM
ZL1modified's Avatar
Install complete *pics added*
So i got the 3:23's, ss3200, crane 227 and everything else from this post https://www.camaroz28.com/forums/sho...d.php?t=610082 installed and today i finally got all the little quarks worked out and fluids topped off-ya know, all that fun stuff...
i also went with the slp lm2 bullet muffler as opposed the the lm1 that i had been running and i'm very glad i did that also...
Right now i am 26 miles in on my ss3200 150 mile break-in period but i can tell is...
This car is gonna haul some ***! i'm thinking low 12's
you all have helped me out tremendously and i would like to give you all a big thanks...
THANK YOU
MODS:
Engine:
- Electric Water Pump
- Comp 10308-1 valve spring kit
- Comp Pro-Mag 1.6 NSA Roller Rockers
- Lingenfelter cold air intake
- ARP fuel pressure regulator
- Crane 227 cam 210/224 duration, .510/.552 lift, 112 lsa
- LS7 lifters
- Cloyes double roller timing chain
- 7.200 pushrods (almost midlift)
- 30# SVO fuel injectors
- 1LE intake elbow
- LT4 valve covers w/cap and pvc breather line
Exhaust:
- Pacesetter Long tubes, coated
- Pacesetter Off Road Y-pipe
- SLP LoudMouth 2 catback system
Transmission:
- Race Built 4L60E
- Yank SS/3200 Stall torque converter
- B&M transmission cooler
Rear:
- LS1 10 bolt with 3:23 ratio gears
Chassis & Suspension:
- Spohn Lower Control Arms
- UMI Torque ar with G-force brace and drive shaft safety loop
- Ls1 Splindles calipers and rotors
- UMI subframe connectors
Misc.:
- Removed air conditioning
- Removed ABS system
- Removed the Traction Control System
- Added SLP line lock kit
Tuned by MadZ28.com
Here are some engine pics... nothing too spectacular...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jul 10, 2008 | 08:30 AM
Z-RATED94's Avatar
You have a nice list of modifications. Looks to me like you put some thought into this and it should pay off big time. Good job.
Old Jul 10, 2008 | 10:27 AM
truedualws6's Avatar
I'm glad to see you are back together and satisfied with the results. Keep us posed on and track times / dyno numbers. I've been too busy to schedule some dyno time myself, but I'm dying to find out where I'm at now.
BPS
9
Mar 5, 2015 10:51 PM
alphaauto
Feb 5, 2015 05:25 PM
Jan 23, 2015 01:13 PM
Collector Car
Jan 5, 2015 10:58 AM
