Injectors / T-Body
Old Oct 28, 2007 | 08:05 PM
z275plus's Avatar
Injectors / T-Body
Are the stock injectors and T-Body enough to run with the 227 Cam in a 95 Z with shorty headers,2500 stall and 3:42 in the rear,or do I need to go bigger ?
This is a street car only.
Old Oct 29, 2007 | 09:45 AM
The stock injectors will support 355 flywheel HP at 85% duty cylce or less.... push them closer to 100% DC and they will exceed 400 flywheel HP. Doesn't sound like you are quite at the limit, if the only mods are the cam and shorty headers. 48mm TB probably isn't at the limit either.
Old Oct 29, 2007 | 08:32 PM
z275plus's Avatar
What about if you add stock heads with just a 3 angle valve job?
Old Oct 29, 2007 | 08:34 PM
joeSS97's Avatar
That isnt adding much,if anything...so stock injectors are fine.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
