injectors not pulsing
Old Jan 21, 2005 | 06:12 PM
1970z28's Avatar
finished with the engine swap 94 v-6 to a 94 lt1. did not have spark from coil yesterday done the checking and replaced the opti. now getting real good fire, can spray the inside of the intake with fuel and it fires and runs until the gas is gone. can turn engine over and over and it tries to hit but just want, spray gas in it fires right up until gas is gone. please help..
Old Jan 21, 2005 | 06:14 PM
sw89lt1's Avatar
Re: injectors not pulsing
did you check the injector fuses?
Old Jan 21, 2005 | 06:17 PM
1970z28's Avatar
yea the 7.5 under the hood.
Old Jan 21, 2005 | 06:48 PM
Dave89IROC's Avatar
do you have fuel pressure?
Old Jan 21, 2005 | 10:18 PM
1970z28's Avatar
do have .but dont know how much, will find out tomorrow.
Old Jan 22, 2005 | 05:27 AM
sssalah's Avatar
Is the pcm getting the low res signal from the opti, this is the signal that the pcm uses to fire injectors.
Old Jan 22, 2005 | 08:28 AM
1970z28's Avatar
how do i check the low res signal from the opti
Old Jan 22, 2005 | 11:50 AM
1970z28's Avatar
ok i have 42# of fuel pressure. used a noid light no pulses from the light. i have power to the inj. with the noid light in the harness i checked the power to the inj. and have power on both sides of the harness where it plugs into the inj. what to do now...
Old Jan 22, 2005 | 01:26 PM
1970z28's Avatar
just tried to pulse inj. only have one inj. spraying fuel. the rest are either clogged up or stuck. any trick to freeing them up .
Old Jan 22, 2005 | 03:40 PM
GreenDemon's Avatar
The computer pulses the injectors, so your problem is most likely there if the wiring is good and spark is present. Are you sure it's not a problem with the antitheft system? Lots of people forget that step with engine swaps.
Old Jan 22, 2005 | 06:52 PM
sw89lt1's Avatar
any luck?
Old Jan 22, 2005 | 07:42 PM
1970z28's Avatar
just got the computer back from ion. had the vats disabled,air,egr, and speed limiter.when trying to crank it this evening it hits but that is all. pulled all the inj. out and found 7of the 8 were not even clicking. guess the intake had been sitting up for a while. with a little shop air and a can of carb. and choke cleaner got the to start clicking and unstuck, so i am letting them sit soaking till tomorrow.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
