injectors
injectors
what size injectors do i need for mod's in sig? are the stock ones big enough? also if i build a 383 this summer will the injectors i buy have to be replaced again?
This calculator is pretty handy for injector sizing:
http://www.smokemup.com/auto_math/fuel_injector.php
Guest
Posts: n/a
I have good logged data before and after a switch to 30# SVO injectors. I was seeing 90+ duty cycle between 3400-4400 at 85% throttle with stock injectors. Since changing to 30's with fuel pressure at 44psi I have set computer injector constant to 33.13 to get blm's right at part throttle. I have monitored a 68% duty cycle between 5100-5600 at 100% throttle. I have not pushed the new engine too hard. I would think this would support 150 dry nitrous with the fuel pressure at 48 or so. If you don't want to jiggle the fuel pressure you would probably want a true 36# or 38# injector rated at 43.5 for any dry nitrous. The 30# SVO's I am using are rated 39.5 psi.
Originally posted by IDOXLR8
I would say 30 lbers if you plan on a NA 383 or 36lbers if you plan on spraying it.
autoxr166
Sep 25, 2015 04:21 PM
