Injectors for 396 Stoker
Old Apr 13, 2004 | 08:51 AM
1BAD-SS's Avatar
Just wondering what some of you guys are running. I have noticed a lot of people running 30 lb/hr injectors, which is what I run. In the 1/8 mile, my duty cycle pegs over 100.
Anybody out there running larger injectors with more success. I am thinking of 42 lb/hr injectors. With the new solid cam, and DP Fogger I don't want fuel to be an issue.
Any info is greatly appreciated.
Thanks,
Craig
Old Apr 13, 2004 | 10:03 AM
IDOXLR8's Avatar
If you are running 100% duty cycle then you need bigger injectors. Ideally, you would like to be around 85% duty cycle.
Old Apr 13, 2004 | 11:12 AM
ElevensOrBust's Avatar
I spoke with the guys that build Baxter's, Injuneer's and McMullen's rides (Second Street Speed) and they recommended 42-lb injectors for my N/A 383 motor. They felt that the larger size was not a big deal, if the PCM was programmed properly.
Old Apr 13, 2004 | 01:34 PM
1BAD-SS's Avatar
Thanks for the info. Let me know what kind of injector offsets and other misc. fuel tuning that ends up working for you.
Old Apr 14, 2004 | 10:39 PM
Lt1tko5o's Avatar
I just ran into this problem, I was running 24 # SVO with my 396 stroker. At 6200 rpm, my injectors were at 106%. I bought 30 # SVO and re-programmed the computer for the injectors. I'm now at 76% at 6200 rpm. The 30lbs injectors are big enough for me and they are only $239 thru summit.
Brian
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
