Injectors
Old Jun 6, 2003 | 12:30 AM
rdavis93's Avatar
Injectors
Ive got a 93 z28 w/ cc305 +about all the bolt-ons (A4). I have an intake leak so when I fix that I was prolly gonna put in bigger injectors and an adj fuel pres reg. Am I gonna add any hp? Do I really need the computer reprogrammed? What size inj would be good?
Old Jun 6, 2003 | 12:31 AM
madwolf's Avatar
With your setup, I'd go with some 24# SVOs. Programming would be recommended as well.
Old Jun 6, 2003 | 12:34 AM
rdavis93's Avatar
Does programming really matter? I would rather not spend another 150 to get the thing reprogramed again if I dont really need it yet. Any power added????
Old Jun 6, 2003 | 12:41 AM
thewinner's Avatar
programming helps alot!
Ion, im curious to why you recommend 24# injectors when the cars come stock with them? (maybe the 1993 cars didnt? or the SVOs actually flow more?) just curious, not a flame.
Old Jun 6, 2003 | 12:43 AM
rdavis93's Avatar
im pretty sure that 93s came w/ 22# injectors. I'll prolly just get 30# then if I have to get it programed.
Old Jun 6, 2003 | 12:44 AM
madwolf's Avatar
I think 30s would be a little too much for him. Accel also makes 26 pound injectors, but I don't like Accels.
The 93s came with 22 pound injectors which means he's maxing them out pretty much. The Ford SVOs were rated as 24 lb/hr at 39.2 PSI. On our pressure of 43.5 PSI, they will flow just around 25.5 so that should provide enough fuel.
Old Jun 6, 2003 | 08:28 AM
RdRacerZ28's Avatar
I'm right with ya Madwolf.....Accels are horrible but people buy them because they are cheap. Accel 30's actually flow 27-28. Typically too big for a 350 CI engine...the ECU can't shut them down enough at Idle. SVO are made by Bosch and are much better quality.
Old Jun 6, 2003 | 09:07 AM
Chris'SS #2152's Avatar
DO NOT GET ACCEL INJECTORS.....THEY SUCK!!!!!!
I bought a set that was mis matched which I guess they do alot.
Old Jun 6, 2003 | 09:47 AM
IDOXLR8's Avatar
As stated earlier you should get come SVO 24lb injectors, AFPR, and programming (for the cam). When I installed an AFPR on my car I picked up 10 rwhp and 17 rwtq just from increasing my fp from 39 psi to 41 psi.
Old Jun 6, 2003 | 12:49 PM
donot_4get's Avatar
Idoxlr8,
What do you have in your car that requires "83 lb Sieman injectors"
how about a 350/355 with a c306 and ported heads? what injectors should I get?
leo
Old Jun 6, 2003 | 12:50 PM
madwolf's Avatar
Originally posted by donot_4get
Idoxlr8,
leo
30# SVOs will be perfect for that setup.
Old Jun 6, 2003 | 01:53 PM
RdRacerZ28's Avatar
I'd love to see the spray pattern on those Siemens injectors hehehe those and Tomco basicly don't have one. Just a straight stream of fuel coming out. Like pissing on a rock lol
Old Jun 6, 2003 | 01:55 PM
madwolf's Avatar
Perfect comparison! (it's called a "pencil stream" BTW)
Here's some Siemens 95s for ya!
Also see some Bosch 88s here. Looks like a much better pattern to me...
Old Jun 7, 2003 | 05:38 AM
donot_4get's Avatar
Thanks madwolf!
I bet you'll get a lot of gallons per mile with those "Siemens 95s"
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
