Injector size
Old Mar 19, 2004 | 11:32 AM
My Red 93Z-28's Avatar
Question Injector size
are 30lb injectors good enough for LT4 conversion kit or should I go with 36lb?
Old Mar 19, 2004 | 11:45 AM
RE AND CHERYL's Avatar
30lb is just fine.
Old Mar 19, 2004 | 11:54 AM
how much hp are the 30lb injectors good for?
Are the Accel injectors good to use?
Old Mar 19, 2004 | 12:17 PM
Kraest's Avatar
Retired
When you're talking about LT4 conversion... Are you talking about the LT4 intake, LT4 cam (hotcam?), etc?
If so, the stock injectors will work fine to around 390-400 rwhp, which isn't even close to what a "LT4 conversion" will give you.
Mike
Old Mar 19, 2004 | 12:50 PM
bored .030 over, LT4 intake, LT4 hotcam, LT4 heads, hooker LT's, hooker y-pipe, cold air, crane ignition, 58mm TB
Old Mar 19, 2004 | 01:42 PM
Cool
I tend to think that's pushing it a bit. The general rule is it you have to go over 80% duty cycle, you need bigger injectors. Can't remember who but someone said they are using stock injectors in a 383 with like 370 RWHP and runnig a duty cycle of 90-95%. Thats too high. I'd be safe and get bigger injectors.
my 2 cents worth
Old Mar 19, 2004 | 05:30 PM
Kraest's Avatar
Retired
My guess with the LT4 "conversion" is 350-360ish rwhp. I think injectors won't be necessary.
Mike
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
