injector size
Old Apr 23, 2003 | 11:05 PM
alexis01's Avatar
injector size
Just curious as to what size injectors you think I should go with. I have a 94 z w/ procharger 8lbs. kit and stage 2 ported heads... I was thinking around 36lbs, but thought i'd check before i bought some..
Old Apr 23, 2003 | 11:12 PM
hvyss's Avatar
I think 36lb SVO's will work fine. I also would suggest upgrading your fuel pump to a 225l Wabro or which ever you choose at the same time. You will need the extra fuel for the blower.
HVY SS
Old Apr 24, 2003 | 05:13 AM
badass383's Avatar
Here's a place that can help if you like. To size injectors you need to know the HP output expected.
http://www.smokemup.com/auto_math/fuel_injector.php
Also my own opinion is don't waste your time with intank pumps. Get an inline and a good filter. This way if and when it goes bad you don't have to go through the trunk floor or worse remove the rear and exhaust to replace it.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
