Injector Question?
Old Mar 26, 2010 | 10:49 AM
DAVE00's Avatar
Injector Question?
Guys,
Got a dumb one for ya but I wanted your opinion. I have a set of ford redtop 30#er's in my 383 and had to pull the fuel rail and replace it this week as I had a crack near the schrader valve again. When I pulled the injectors I noticed all but one of the pintale caps (plastic caps on the end of the injector - manifold side) were gone. After a bit of injenuity I rigged up a plastic hose to my shop vac and fished all of them out of each injector bore without pulling the mani - WOO HOO!!! I seated them all fully back on the injectors very firmly and checked them before I reinstalled the new fuel rail assembly. Questions are I thought these would get pulled into the combustion chamber but I guess there is not enough room through the valve(s)? Also, with these things down in there could it cause some air/fuel turbulence that would cause a little loss of power on my motor? Just curious, let me know what you think. I personally was really supprised that I got all of them out and they were intact.
Old Mar 27, 2010 | 12:53 PM
Slick-Z's Avatar
Hey man your right it would be hard for them to fall down in there and if somehow they did it would clog the fuel travel causing a misfire of some sort.Also man from your statement it sounded like you retrieved all of the rings.
Old Mar 28, 2010 | 07:51 PM
DAVE00's Avatar
Yup got em all out. But they've been bouncing around in there for a few months just wanna know if this can affect performance?
Anyone else???
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LT14LIFE
Feb 9, 2015 09:35 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
