Injector question
Old May 30, 2005 | 02:31 PM
showinoff's Avatar
Injector question
Will LS1 injectors work in an LT1?
Billy D.
Old May 30, 2005 | 02:43 PM
chrism400's Avatar
Re: Injector question
Yes they will.
Old May 30, 2005 | 03:01 PM
showinoff's Avatar
different duty cycle wont cause problems will it?
Old May 30, 2005 | 03:20 PM
joshp007's Avatar
Hey man I am doing the same thing with my LT1. Just get you a adjustable fuel pressure regualtor and you will be ok
Old May 30, 2005 | 04:56 PM
96capricemgr's Avatar
The 28lbs. LS1 injectors will be 24lbs in an LT1 due to the fuel pressure differences. If you are going to use a regulator to make the injectors act bigger(mistake in my opinion) then why not just make the stockers act bigger. Swapping in the LS1 injectors would just screw up the tune since they will respond differently than the stockers, there is more to injector tuning than just flow rate.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LT14LIFE
Feb 9, 2015 09:35 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
