Injector O-Ring lubrication or not?
Old Mar 27, 2006 | 03:27 PM
spm4520's Avatar
When installing new injector o-rings into the fuel rails, should the o-rings be lubricated with anything? I was told that motor oil may actually cause the rubber to break down faster. Is this true?
Old Mar 27, 2006 | 03:29 PM
Rob WS6's Avatar
Re: Injector O-Ring lubrication or not?
I usually use a bit of WD40. Engine oil can deteriorate some rubbers, but I doubt it would do it to injector o-rings.
Old Mar 27, 2006 | 03:36 PM
Xleratorss's Avatar
I use this stuff, can't beat it for rubber isolator and o-ring installations http://www.ipcol.com/prod-p80.htm
Old Mar 27, 2006 | 03:43 PM
Xleratorss's Avatar
I am by no means a dealer or rep for these guys but this stuff works. Also, take a look at this application chart for the other uses.
http://www.ipcol.com/automotive-app-chart.htm
Old Mar 27, 2006 | 03:44 PM
rtrigg's Avatar
I have been an engineer in the "sealing" industry for about 10 years. So, I'm familiar with most all o-ring compounds. The safest lubricant to use for assembly purposes are water based lubricants. These are pretty much safe on every rubber compound. However, they are not readily available...unless you want to go buy some KY Jelly. But, KY does work well That being said, most injector o-rings are Nitrile-Butadiene...better known as Perbunan, Buna-N, or BUNA. These are suited for contact with petroleum based lubricants. A better o-ring choice would be Fluorocarbon...better known as VITON. VITON cost a little more than BUNA, so the OEM's go with the cheaper material. If you want to go exotic, you could use KALREZ...but they are $50/ea in this size range
Regards,
Ronald Trigg
Old Mar 27, 2006 | 04:55 PM
sabre81's Avatar
you don't NEED to lubricate them. Just makes the injectors easier to seat into the respective holes.. Especially good with new o-rings
Old Mar 27, 2006 | 05:11 PM
LameRandomName's Avatar
Dish soap. It softens your hands WHILE you install your injectors.
Old Mar 27, 2006 | 05:36 PM
jkucz31's Avatar
just use any lube hahaha your not going to keep the car long enough to notice the deterioration of the o rings
Old Mar 27, 2006 | 05:57 PM
turbo_Z's Avatar
Ill agree it doesn't matter what you use because any lube is better than none at all. If you dont lube the O-rings then you risk tearing them. I didnt use lube once and thought it was alright till a few weeks down the road an O-ring sprung a leak! Be careful.
PoorMan's Avatar
So just spit on them.
Old Mar 27, 2006 | 06:31 PM
CMoney's Avatar
Merpol.
Old Mar 27, 2006 | 07:43 PM
BMAN'S SCZ's Avatar
AKA: Prison Lube LMAO
Old Mar 27, 2006 | 08:07 PM
97WS6Pilot's Avatar
Motor oil is designed to not deteriorate seals and Orings. No other lubricant has had more research done on it.
Old Mar 27, 2006 | 08:35 PM
Loadre's Avatar
I use a little silicone based lube. Never had a problem.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
