Injector Help
Old Apr 11, 2006 | 08:24 AM
MPB70350's Avatar
Injector Help
I am planning on switching out my injectors and have a couple questions. First i have heard bad reviews on Accell so what are some good brands to look into? Also I have heard that you can get yours cleaned and rebuild, where they also test to make sure they are flow matched perfectly and spray patern is the same, is this a bad idea? its 12.95 per injector. Also what is the stock injector size and should i go bigger with a bolt on motor, with plans of a cam and header swap in the next few months?
Old Apr 11, 2006 | 09:02 AM
Re: Injector Help
Might want to add a "signature" with info about the year of your car, major mods, etc. Not all LT1's are the same.
Stock injectors in 93 are 22#/HR, 94-97 are 24#/HR. A lot of people find that the various versions of the SVO, FMS, Bosch, Denso, etc pintle style injectors provide good performance for low $$$$.
I've had injectors cleaned and flow matched, but I'd be surprised if it only cost $12.95 each.
http://www.tpis.com/index.php?module...egory=Services
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
