Injector??
Old Dec 1, 2003 | 01:11 AM
turbostud2's Avatar
Injector??
Ive got a 96 Trans am with the hot cam LT4 heads 1.6 roller rockers Hooker LT's and LT1 edit and some other small stuff. I was wordering what size injectors you think I should put on it?? Also what injectors are the best for the money??
Old Dec 1, 2003 | 01:20 AM
'94 Bad A Z28's Avatar
Your stock injectors are perfectly fine for what you have.
Old Dec 1, 2003 | 01:43 AM
97WS6SCharged's Avatar
Agreed. Don't upgrade the injectors until you need them. The stock ones are good to probably 450 horses at which point you will also need a better fuel pump as well.
Old Dec 1, 2003 | 02:00 AM
96z's Avatar
96z
I would just repeat everything already said.
Old Dec 1, 2003 | 02:30 AM
S.J.S.'s Avatar
I went with all the mods below and only put in 30#'s. The stock ones can handle up to like 400rwhp.
Old Dec 1, 2003 | 02:55 AM
GT40MkI's Avatar
you need to upgrade
yes stock one will work but the duty cycle will be well about 95%
to many guys on this board run to small of injectors
Old Dec 1, 2003 | 02:57 AM
Originally posted by GT40MkI
you need to upgrade
See sig. lol...
Old Dec 1, 2003 | 04:25 AM
S.J.S.'s Avatar
you need to upgrade
Was that for me?? Well either way thats not true. Neither of us need to upgrade. Go do some searches on the topic. There are many guys who get their car Dyno Tuned that will justify that statement.
My friend is running 10.80's with just heads, cam and tc on his 02 LS1 with 30#'s. When he put it on the dyno it was more than sufficient. Oh yeah thats with a 175 shot.
Old Dec 1, 2003 | 02:57 PM
GT40MkI's Avatar
dont go by everything you read on the board
do the math on injector duty cycle. most dyno tune guys cant read injector duty cycle anyhow.
and fyi the 175 has nothing to do with the injectors, if its a wet kit
but its your car have fun. burn some injectors up and hope they dont lock up.
fyi a nice resource http://www.z31.com/software/injector.pl
shoot for 85 duty cycle and dont forget you need to calculate FLYWHEEL
Old Dec 1, 2003 | 03:24 PM
jonaddis84's Avatar
Either way, not something you want to screw around with, run a cylinder too lean and youll wish you bought those nice overkill injectors, if you get them might as well go overkill, 42s if you plan on going bigger and better in the future.
Old Dec 1, 2003 | 09:05 PM
GT40MkI's Avatar
true 42s are only $300 now
Old Dec 1, 2003 | 10:35 PM
VeryBad's Avatar
Until you change the PE (power enrichment) tables with LT1edit the injector duty cycle is going to be what it was originally programed at the factory. At WOT the PCM is open loop and uses a lookup table. Monitor your duty cycle and think about upgrading when if it gets much over 90%.
You can always raise the fuel pressure some to keep the duty cycle down, but don't go too high. You will need to do some PCM programming.
Good luck,
Gordon
WitchHunter Performance
Fuel Injector Cleaning & Flow testing
http://www.witchhunter.com
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
