information greedy newbie question
Old Feb 6, 2004 | 06:47 PM
airborneluva's Avatar
Question information greedy newbie question
lol was i suppose to take some kind of coupler OFF my old water pump and put it ON my new one or did the new one suppose to come with the coupler attached already lol /sigh. I didnt read anything about that. If so ..how do i get the old coupler off and ..install on the new one. /sigh ...might explain why im overheating ..thanks guys,
josh
Old Feb 6, 2004 | 07:13 PM
MEAN LT1's Avatar
Re: information greedy newbie question
josh
Dont know what your ttalking about. If you bought a replacement waterpump for your car the only thing you should need is gaskets.
Old Feb 6, 2004 | 07:23 PM
4S Concepts SS's Avatar
HEH - If he bought a new waterpump he's probaby going to need a new OPTISPARK in a month or so LOL! Seriously though, I have no idea what you are talking about either....
(And my gaskets were free at autozone!)
Old Feb 6, 2004 | 07:40 PM
AsianSensation's Avatar
I just pull my coupler off straight out. The coupler can sometime be stuck on the water pump housing bearing or wp drive shaft.
Old Feb 6, 2004 | 09:32 PM
If you left the coupling off (which I hope you did not), your water pump is not even running.
It does not come with a pump and is quite expensive if you lose it.
Old Feb 6, 2004 | 10:31 PM
ok, the waterpump i removed still has the cylindrical "coupling" on the back ...i cant see the lil grooved nub. So I need to remove that and put it on the NEW pump? Should it just slide off? Thanks
Old Feb 6, 2004 | 10:38 PM
b-stevens's Avatar
Old Feb 6, 2004 | 10:39 PM
It just slides off. It couples the two splined shafts. Clean it up and put a little new grease inside the ends or on the shafts.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Z28countrymama
Jan 22, 2015 02:50 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
95dzz28
Jan 12, 2015 05:58 PM
Brad 97z
Aug 10, 2002 09:58 AM
