Info needed on fuel pump install
Old Jun 17, 2005 | 03:41 PM
keng's Avatar
OK I have the tank out and the pump is in cased in a plastic housing.
Will I need to reuse this plastic housing? and what do I seal it with if I do need to reuse it?
Also when I pulled the pup out there was a rubber line with a curve at the end, this line was not connected to anything, is this normal....
Old Jun 17, 2005 | 04:39 PM
TruDualed95Z's Avatar
Re: Info needed on fuel pump install
http://www.taekwondoplus.org/z28/fuelpump.html
http://www.geocities.com/formulapower2/fuelpump.html
There should be info in these sites that'll help you along.
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
