Info/help/tips on diy head porting
Old Jul 31, 2003 | 10:54 PM
stik6shift93's Avatar
I have an extra set of lt1 heads I was looking to port out, but don't know where/how much to take out material in the intake/exhaust runners. Also for the chambers should I just clean out flash and polish them, or is there material I can take out to give the head a better swirl and combustion efficiency?
Thanks in advance
Brad
Old Jul 31, 2003 | 11:45 PM
Compstall's Avatar
There are many books/magazine articles on porting. There have been some GREAT articles on it in recent months in Hot Rod, Super Chevy, Car Craft, etc.
If you're a first-timer (like me), don't plan on hogging them out just yet (without EXPERIENCED help). Reducing the valve guide diameter inside the bowl and removing the casting flash/roughness can easily give you ~20 hp. I have read in many articles and books that the polishing of the ports is mainly for cosmetics and doesn't really do anything for performance, but won't hurt anything if you do it.
Old Jul 31, 2003 | 11:46 PM
SVT Killer LV's Avatar
Remember where the air flows.. ALONG THE ROOF.. increasing your efficiency where they need to flow is where you're going to make the HP's
Old Jul 31, 2003 | 11:53 PM
LoL, I didn't plan on polishing the ports just the chambers to prevent carbon buildup. Maybe once they come out with clear intakes I'll give the runners a shot . Thanks for the help, keep it coming
Old Aug 1, 2003 | 12:16 AM
why not port match it at least? and clean up the ports.. might as well.. then again while you're there, new cam, springs, rockers, hell while your at that, just pull the motor and drop a stroker in... should i continue?
Old Aug 1, 2003 | 12:18 AM
Since they are a spare set, just take your time work diligently and port the hell outta those things
Old Aug 1, 2003 | 01:23 AM
Ryan 97 Ram Air T/A's Avatar
Go to the Standard Abrasives website. They have excellent step by step instructions you can download.
http://www.sa-motorsports.com/diyguide.shtm
oldschool
Feb 9, 2016 09:21 PM
Dmonty
Jun 2, 2015 11:19 PM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
