IMPORTANT. Anybody know the part# or where I can buy this from?
PLEASE HELP. Anybody know the part # or where I can buy this from?
I just found out that huge air filter on my K&N cold air kit fell off again. How long my engine's been sucking in dirty air I have no idea but I've finally gotton fed up with the air cleaner coming off. No matter how much I tighen the clamp, it just keeps coming loose. It's a good thing I have a mesh net under it to catch it when it fall's otherwise I'd be buying a new filter every other day.
I've decided to remove the whole air intake set up and just attach an air cleaner directly to the throttle body. I got the idea when I saw a friends GM fuel injected 502 crate motor. It comes with a conical shaped air filter that attcaches directly to the throttlebody. It looks awesome. I've included some pic's and I was wonderinng if any of you knew the part # or could direct me to some place I can order it from for my LT1. It looks sweet and really cleans up the engine compartment a lot. I know the air it'll be sucking in won't be as cold as it would be with the cold air kit, but I think that the fact that there's no tubing, it'll also be a lot less restrictive. That should make up for the whatever loss in hp I'd get from the hotter air. Throttle response should also be a lot better. The intake will also be a lot louder too.
Thanks in advance.
Ps. The pic's above are of an LT1. ....looks sweet
The last ione is of a GM 502. That's pretty much the set-up I'm looking for.
carguyshu
Jan 22, 2017 11:19 AM
May 15, 2015 10:43 AM
NewsBot
Jan 8, 2015 11:29 PM
