Impala Head Gasket
Old Apr 3, 2007 | 02:34 PM
jclt12003's Avatar
Impala Head Gasket
hey guys i'm doing a cam swap stock heads can i get away with using the impala head gaskets for some extra compresion ratio and also would that mean i have to change my pushrod length. Thanks for all the info
Jason
Old Apr 3, 2007 | 02:39 PM
Brandon94Z28's Avatar
You can run them with stock pushrods. I just replaced my head gaskets and I was going to use the imp head gasket but I have heard mixed reviews. A reputable engine builder in my area also told me it wasn't a great idea since they were used designed for iron heads. I took his advice and went with stock fel pro replacement.
Do a search on the topic, there is a boat load of info.
Brandon
Old Apr 3, 2007 | 02:42 PM
jclt12003's Avatar
yes i looked and did the search but all i kept coming up with was things for decked heads. My heads are stock thanks
Jason
Old Apr 3, 2007 | 05:20 PM
SS MPSTR's Avatar
the impy headgaskets work just fine with either aluminum or iron heads.
Old Apr 3, 2007 | 05:48 PM
maybe2fast's Avatar
I hope so! because I am looking forward to close to 11.0:1 compression after my heads are done
Old Apr 3, 2007 | 05:50 PM
SS MPSTR's Avatar
I'm ~ 12.4:1 SCR.
Old Apr 4, 2007 | 07:29 AM
chrism400's Avatar
Victor Reinz 5898 is .026 for LT1. Either the Impala gasket at .029 or the Victor Reinz gaskets are fine. Apparently the Mr Gasket set has problems with the shrink wrap but I have never seen an actual package. If you use ARP studs or bolts, go with the stock torques, not the ARP torques.
Old Apr 4, 2007 | 08:40 AM
Z-RATED94's Avatar
Same here, no problems.
Old Apr 4, 2007 | 09:37 AM
speed_demon24's Avatar
Cometic .027 4.01 bore gaskets here. After my 2nd set of mr gaskets came ****ed up from the packaging I returned them and ordered some Cometics and haven't looked back.
Old Apr 4, 2007 | 10:21 AM
Z28SORR's Avatar
Where did you get this from??? Torque is based on the bolt/stud material, not the head material or the gasket material. If you under torque the bolts you will not stretch them enough, and you wont get the proper clamping force. They could eventually come loose.
Old Apr 4, 2007 | 03:40 PM
chrism400's Avatar
Originally Posted by Z28SORR
Where did you get this from??? If you under torque the bolts you will not stretch them enough, and you wont get the proper clamping force.
If it's a chair, sit in it. If it's a car, drive it. If it's pizza, eat it. If it's an ARP stud, torque the long bolts to 77, and the short ones to 65.
Old Apr 4, 2007 | 03:42 PM
chrism400's Avatar
In other words, let the experience of others save a headache later .
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
