I'm Clueless, need opinions please.
Old May 14, 2004 | 12:26 PM
My Red 93Z-28's Avatar
Exclamation I'm Clueless, need opinions please.
Alright, my car has a miss in the #8 cylinder. We know it's #8 because when you unplug the injector the engine never slows down. The Injectors are fine as we switched them around and had the same result. The car is smoking quite a bit. The valves have been adjusted once with the car off.
Could it be the opti not sending a spark to the cylinder, should we adjust the rockers with the engine running??? I'm at a loss.
P.S. We hooked a computer up to it and it is showing quite a bit of knock. It ranged from 1-4 on some type of Mac Tools scanner.
Any ideas as to what could be wrong.
Old May 14, 2004 | 01:14 PM
Silver's Avatar
well you eliminated the injector but have you tested the plug and the wire?
Old May 14, 2004 | 01:41 PM
Brand new Accel Extreme 9000 wires, pulled the plug out and it looked ok
Old May 14, 2004 | 01:53 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
can you swap the plug with a different cylinder?? i am not trying to be a smart a$$ but just looking at the plug doesn't tell you for sure that it's good. pick up a new plug on the way home just for troubleshooting purposes. how many miles on that opti??
david
Old May 14, 2004 | 01:57 PM
quite a few, my buddy has an opti out of a parts car we might swap out as a last resort if nothing else seems to work.
I was thinking about going ahead and getting new plugs.
I wish the bad one wasn't on the #8 cylinder though, that thing is a bitch to get out.
Old May 14, 2004 | 02:18 PM
LPEdave's Avatar
Have you verified that there is spark at the plug wire? Pull the plug wire off the plug, turn the engine over, and see if you get spark jumping from the wire to the block. That'll test your opti.
Dave
Old May 14, 2004 | 02:30 PM
won't that shock the P*ss out of me?
Old May 14, 2004 | 02:45 PM
LPEdave's Avatar
Heh, I guess I could have been more clear...
Pull the plug wire off the plug, and rest it somewhere so that the connetor is about 1/2" away from the block. Keep your hand away from the general area, but the spark is going to jump (if it exists) from the wire to the block. Watch while someone in the car cranks over the engine. It'll be easier if it's darker, say in a garage.
Dave
Old May 14, 2004 | 02:55 PM
TraceZ's Avatar
HAHAHAHA. That is funny. It reminds me of the time I grabbed the spark plug end on our lawnmower while it was running. I was about 5, it put me on my rear!
Thanks for the good laugh.
You might want to swap the injector with one on a different cylinder also. Maybe that one isnt working right and little or no fuel is getting to #8.
Old May 14, 2004 | 03:07 PM
Super Slow '97's Avatar
He already swapped the injectors around. I agree with the spark side of the equation try what the other guys have been saying Hope you figure it out.
Old May 14, 2004 | 04:23 PM
I'll have to try that this weekend if I get a chance.
My prom is sat. so I might not get around to it until Sunday if I do at all.
Thanks for the replies so far, keep them coming.
TABAHR - Glad I could make ya laugh.
Old May 14, 2004 | 05:12 PM
Dude skip the Prom and work on your car I am sure she will understand. Well J/K have a good time let us know what you figure out about the car.
Old May 14, 2004 | 10:22 PM
Well, unfortunately it's starting to look like it's the opti-spark.
There goes this week's paycheck, and probably next week's paycheck.
Old May 15, 2004 | 07:48 AM
Hey man do a search for Dal he is a parts supplier for a dealership and he has great prices I just got a vented opti for $198 the un-vented that you will need is more expensive but giv him a call 1-877-448-5451. Maybe you should consider doing a vented opti conversion. Not sure what you need to do for that but just a idea.
Old May 15, 2004 | 12:04 PM
I was thinking of doing a vented opti swap, but didn't know if I would need anything else or if they swapped out no problem.
Anyone know?
