Im back, got some questions.
Old Mar 12, 2013 | 09:25 PM
ascastil's Avatar
Ok, I stepped back and took a deep breath and now me and my Camaro are friends again, although he is very upset I bought a set of heads and intake for my LS1 TA. Anyways, Im a little disappointed with my last visit to the track. After a dyno tune and making 392 whp, I ran a 12.68@108, 1.78 60ft. Another run was 12.65@108, 1.82 60ft. I was running slicks on some steel wheels I think at 25psi, hooked pretty good. I wasnt launching that hard, under 3k rpm. I got lca, relocation brackets, panhard bar. I got weld in subframe connectors, but they arent on the car. I was thinking it should be faster, way faster. Im running a Hughes 3k stall, Im wanting to upgrade to a 3600 or bigger. Could my stall be hurting times? Would it help a lot to upgrade?
I think I only gained like 2mph even after the HCI and dyno tune, not sure if the tune is even nuts on. I was thinking about obd1 to get a better look at whats going on with the pcm but I need to pass emissions. Another option would be a 24x swap, but dont know if thats really necessary. Both options would require a completely new tune on the pcm, there is $500+ right there. When it was getting tuned, he had software but was only able to monitor a handful of things, basically enough to get the job done. Ideas, suggestions? If you need any more info, let me know.
Old Mar 12, 2013 | 09:27 PM
ascastil's Avatar
Re: Im back, got some questions.
Also, looking at an Edge 3600 converter in the for sale section. Is a 4l60e the same as far as LS/LT motors go? Would it fit if it was for a 97 vette?
Old Mar 13, 2013 | 08:29 AM
yanal_13's Avatar
Not an expert but depends on the track you where at. Elvation , density and humidity also play big role in you times but your trap speed is pretty good for a mid 12's car check back the curves of afr and maf and pist some pics of that too als i rhink you should als post you power and tourque curves that will how you tune was.
Old Mar 13, 2013 | 01:10 PM
PWR SHFT's Avatar
Your trap speeds do not match your HP. You should be trapping in the 112 to 115 range with that hp. IMHO, you should get it re-dynoed and scanned to see what it going on. At a minimum, I would do a scan during a run and see what it is doing. Something is not right.
Old Mar 22, 2013 | 11:36 AM
JakeRobb's Avatar
Super Moderator
I'm 99% sure that the 4L60E from a C5 Corvette will NOT fit a Camaro; that's the transaxle version.
I would think that 3600 is plenty of stall. Your 60' times are great, so I don't see any reason to change that.
I agree with PWR SHFT; your dyno numbers should give you a higher trap speed, but that's based on some assumptions, both about your dyno run and about your track day.
Dyno questions: What kind of dyno did you make 392whp on? Most of us are accustomed to numbers from a Dynojet, but other dynos read higher or lower for the same actual power. Did you run it in 3rd gear? Does your converter have a lockup? Was it locked during your run?
Track day questions: I see you're in Phoenix. What's the elevation at your track? How hot was it that day?
I put 325rwhp down on a dynojet in 4th in my M6 car. That's equivalent to your 3rd gear if your converter was locked, and I regularly trap 107-109mph. But I did all of that at 600 feet of elevation on a 45-degree day, and the lower-density air you get on hot days and/or at higher elevation can make an enormous difference in terms of the actual power your engine can make.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
sscott
Jan 17, 2015 04:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
Hurin
Dec 13, 2014 07:38 PM
