ILE vs Stock Trans mount
Old Feb 1, 2004 | 03:19 PM
97ss497's Avatar
Question ILE vs Stock Trans mount
I'm currently installing a BMR torque arm and as long as I'm at it will install a new trans mount. What is the difference between a ILE 22146231 mount and a stock 22201140 mount? I've heard the aftermarket poly mounts create too much vibration in the car.
Any opinions???
Old Feb 1, 2004 | 03:32 PM
FlyboyZ28's Avatar
I can tell you I have had a poly mount in for about 1.5 years and even though peopl say it will finally break in...it still vibrates. I dont know much about the 1le except that it is stronger than stock. I am doin a rebuild with heads and cam so I'm glad i have it now, but with basically stock motor the poly was almost too much vibration.
Dan
Old Feb 1, 2004 | 08:17 PM
Re: ILE vs Stock Trans mount
Any opinions???
The 22146231 is no longer available. They replaced it with another number that covers the stock mount and 1LE and it is more like the stock mount. Some people have been using an LS1 mount that seems to be better (more like the old 1LE).
Old Feb 1, 2004 | 08:21 PM
JasonK94Z's Avatar
Thumbs up
I've had the LS1 mount on my car for about 4 yrs now. Its still holding up.
Old Feb 1, 2004 | 08:32 PM
Kain's Avatar
IMO, I'd just get the poly mount. Those who say it vibrates too much are panty-waists and should be driving Caddys for their smooth ride.
Old Feb 1, 2004 | 08:36 PM
Curt (pres AAMC & ZAA)'s Avatar
The LS1 has a torque-limiter so it won't tear like the stock or 1LE mounts do - highly recommended.
Old Feb 1, 2004 | 09:00 PM
SlickBlack Z's Avatar
Ive had a Poly mount for about 8 months....Id recommend it. It doesnt add much noticable noise, and It really stiffens up the trans(the shifter doesnt move as much). Also , If you have long tubes, this mod will minimize exhaust movement as well.
Old Feb 1, 2004 | 09:26 PM
Brundle's Avatar
Re: Re: ILE vs Stock Trans mount
I phoned the dealership a week or two ago and they said that the part number that replaced 22146231 is 22201140. They just combined it into the newer part number from the sounds of it. I'm thinkin about going with this newer LS1 mount after havin gone through a poly mount and not liked it at all.
Old Feb 1, 2004 | 09:42 PM
ba96ta's Avatar
I think vibration problems are worse with the autos. I didn't notice much difference with mine
Old Feb 1, 2004 | 09:43 PM
97ss497's Avatar
So what is the LS1 mount part number????
Old Feb 1, 2004 | 10:08 PM
Re: Re: Re: ILE vs Stock Trans mount
Originally posted by Brundle
I phoned the dealership a week or two ago and they said that the part number that replaced 22146231 is 22201140. They just combined it into the newer part number from the sounds of it. ...
I think that is what I previously said.
I didn't bother with the new p/n, because no one is going to want it, anyway.
Old Feb 2, 2004 | 08:06 PM
97ss497's Avatar
I called the local GM dealership today and got the following part number for a 98 LS1 with a 6 speed: 22174970. I'm going to order from gmpartsdirect.com. Thanks everyone, for your input.....
Old Feb 2, 2004 | 08:22 PM
RedHottG2's Avatar
Brundle: you have a PM
Old Feb 2, 2004 | 08:25 PM
hsyr's Avatar
Aren't the LS1 tranny mounts more money than the 1LE mount? When I put a 1LE inplace of my stocker last year my shifter was wayyy stiffer! Probably good to change it once every year or 2 if you do alot of hard lauches and shifts.
Old Feb 2, 2004 | 11:03 PM
Yes, they are more, but as was stated previously, the 1LE is no longer available as the mount it used to be. The combined part number mount is like the stock mount.
HectorM52
Jul 30, 2017 11:46 AM
siguy
Nov 27, 2014 10:07 AM
x7x7
Aug 15, 2002 06:49 PM
