Ignition wires and plugs a power adder?
Old Nov 9, 2003 | 05:55 PM
Briank8811's Avatar
Post Ignition wires and plugs a power adder?
Do race type sparkplug and sparkplug wires actually make a difference in hp/tq and fuel economy? If they are worth it, what are good types?
Old Nov 9, 2003 | 06:02 PM
OBE1 95Z28's Avatar
Plugs and wires don't add power, but worn plugs/wires can rob power. Also as you increase your car's power through modifications (i.e. heads/cam, blowers, nitrous, turbos) the combustion chambers will run hotter and a stock plug can cause pre-ignition. Most guys run colder, non-platium plugs to prevent pre-ignition and an after market ignition box (MSD, Crane) for a hotter spark as higher combustion pressures tend to blow out the stock spark. After market wires tend to have lower resistance, helping the after market ignition boxes delivery the hotter spark to the plugs.
eazyZ
Mar 1, 2015 07:12 AM
Jeff1904
Jan 3, 2015 12:00 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
kandied91z
Aug 6, 2002 01:18 AM
