ignition switch melts!
Old Feb 20, 2003 | 01:36 PM
tom3's Avatar
I replaced 2 ignition switches, the third one is broken again.
For some reason they 'melt' around the starter contact. It is always black there with burnt plastic. The rest of the switch is fine; Maybe too much current flowing through, but I have a stock/rebuilt starter, nothing special there.
Any ideas?
Old Feb 20, 2003 | 02:33 PM
Have you replaced the plug pig tail that is burnt? If the terminal makes poor contact, it will only create more heat. You can get ACDelco part #PT289 to replace it.
Old Feb 20, 2003 | 05:24 PM
tom3's Avatar
that's a good idea; do you know how far does the connector go on the other end? (I don't feel like ripping half of the dash out to change it )
Old Feb 20, 2003 | 05:46 PM
The plug would come with just a short length of wire on it and you would have to cut off your old plug and splice the new one on. IMHO, solder and heat shrink tubing would be best.
Henson071
Sep 18, 2015 04:01 PM
AtlasXVIII
Aug 24, 2015 11:41 PM
Bails098
Aug 17, 2015 05:15 PM
detroitmuscle
Jul 31, 2015 04:21 AM
Jlo
Jul 29, 2015 03:52 PM
