Ignition module?
Old Apr 10, 2006 | 06:06 PM
yzblue125's Avatar
Ignition module?
no spark ,got a new coil and thats not my problem, its basically down to crank sensor, ignition module, or opti. any sugestions thanks,
ps. how do i test these there all expensive and non returnable
Old Apr 10, 2006 | 06:37 PM
Dave89IROC's Avatar
Re: Ignition module?
ok, its NOT the crank sensor, that wont effect spark(for misfire detection only on the 96-97 LT1s), I think shoebox has something on his site to check the opti and module
Old Apr 10, 2006 | 06:49 PM
FastZinTennessee's Avatar
I took my ICM to autozone and they tested it there. Shoebox has some really good troubleshooting guides on his site, check them out.
Old Apr 10, 2006 | 06:53 PM
Evil Eric's Avatar
did you see if the wire from the coil to the opti was throwing an arc when the engine was cranked?
Old Apr 10, 2006 | 07:19 PM
yzblue125's Avatar
yea when i pull the coil wire off the opti and try to arc it, i get nothing
Old Apr 11, 2006 | 12:25 PM
yzblue125's Avatar
So far i have replaced the coil, and the ignition control module and still not even the slightest spark. please any help!! some back ground info was the car was running fine no problems and just died didnt even sputter just died. I was probaly at about three quarters throttle when this happend. if this helps the check engine lite turned on the day before for the first time since ive owned the car but was not on when it died. I guess all i have left is the opti to replace.
Old Apr 11, 2006 | 12:51 PM
A code scan may give you some insight to what the problem is. The Opti will set codes for problems with the optical module.
Old Apr 11, 2006 | 06:15 PM
yzblue125's Avatar
it was the opti, it made it 130k miles RIP
Old Jun 5, 2006 | 02:58 PM
sean1997ws6's Avatar
May sound stupid but did you check the harness where the opti plugs in. both at the top of the opti and alongside the manifold.check that i had the same type thing and it turned out that the plug thing wasnt all the way seated in the top of the opti.
Old Jun 5, 2006 | 07:51 PM
Maybe you didn't notice that his last post said he fixed it (about 2 months ago ).
The harness is a good thing to check, though.
Old Jun 5, 2006 | 08:42 PM
Haha sorry shoe, i was just skimming through..haha sorry bud..
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
tommalcolm
Sep 11, 2015 03:39 PM
