ignition cylinder replacement: turn signal harness removal?
Old Aug 25, 2003 | 06:00 PM
reuter's Avatar
hey im replacin my ignition cylinder on my 95 z28. ive got the steering wheel off, the snap ring, lock ring, turn signal arm removed, hazard switch removed, and the lower half of my dash removed. i got up under there and disconnected the turn signal harness. i need to get the plate (not sure what its called... its the plate that the turn signal arm attaches to and has 4 hex nuts on it) off. am i supposed to feed that thing back through the steering column? the harness itself looks about 2.5" wide and the column base cant be but 2" someone wanna help me out and tell me what to do next?
Old Aug 25, 2003 | 06:22 PM
reuter's Avatar
anybody? im so close to getting to the igniton cylinder i just need this plate removed, the buzzer switch then im good to go. someones gotta know
Old Aug 25, 2003 | 07:33 PM
reuter's Avatar
heres the plate i need to remove
see how it bends forward up top but wont slide out at the bottom? thats where my problem starts.
heres a crappy pic (with nightshot on) of where i disconnected the harness. the harness is pretty damn big to be slidin through the steering column. problem #2
stangspank
Nov 13, 2015 01:02 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
