Ignition Coil, Module and Spark plug wire
Old Jul 29, 2004 | 05:59 PM
kevmor99's Avatar
If I seperate the ignition coil module ('95 LT1) from the bracket that the coil is on (but leave it ICM on the heatsink), can I relocate it to maybe say under the corvette fuel rail covers? I have to relocate the coil/icm anyway for my setup, I just don't know if this will cause any overheating problems for it.
Also, where can I get just one spark plug wire? (The #1 wire will work...)
Old Jul 29, 2004 | 06:12 PM
944v8inDFW's Avatar
Re: Ignition Coil, Module and Spark plug wire
As long as you can make the wires work put it anywhere! The further form any heat the better. You should be able to get a single wire / coil wire at any decent parts store. If you have one that works take it with you and ask whomever to match it.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
