If the waterpump leaks does it mean that it's bad?
Old Oct 11, 2005 | 04:59 PM
SSConceptz's Avatar
Does it mean the waterpump is bad if it leaks? I was just wondering because I replaced the gaskets and it still leaks and put silicone on the outer plate with the bolts and it still leaks, im thinking it's from the waterpump bolts because the car stays under 180
Old Oct 11, 2005 | 05:20 PM
Re: If the waterpump leaks does it mean that it's bad?
If it leaks out the weephole, it is usually time for replacement. If leaking somewhere else, you need to find out why. You should use thread sealant on the bolts.
Old Oct 11, 2005 | 07:53 PM
HardcoreRM125's Avatar
Dont drive it with it leaking antifreeze out of the pump. Its just asking for the Opti to take a **** on you. Unfortunatly, GM thought it was smart to mount the distributor where they did.
Antifreeze + Opti =
Old Oct 13, 2005 | 04:44 PM
SSConceptz's Avatar
Antifreeze + Opti =
Yeah it already runined the opti (I think the opti was a great design) and it is leaking out the weephole. What the hell is it leaking there for?
Old Oct 13, 2005 | 05:09 PM
Dave89IROC's Avatar
the "weephole" actually vents the bearing, but if the internal seal leaks(antifreeze old and acidic, bearing failing, ect.), it leaks coolant out the hole
Old Oct 13, 2005 | 05:30 PM
SSConceptz's Avatar
Couldn't I just replace the bearing etc?
Old Oct 13, 2005 | 05:32 PM
TobyZ28's Avatar
IF its constantly dripping out the wheep hole its timeto replace it. According the the service manual some weepage is normal. They suggest trying to correct it by using these pellets you add to the radiator from GM which may relap the surface of the leak stopping the leak. They also mentioned results may not be apparent until after a week or two. This was only for minor leaks, if your is gushing out the weep hole time for a new WP. WP's arent too bad to replace. Its just a pain if the gasket is stuck on real good ...
Old Oct 13, 2005 | 06:07 PM
SSConceptz's Avatar
Easy to replace to me just where is the best place to get a pump?
Old Oct 13, 2005 | 07:42 PM
ZMAN Z28's Avatar
You could always go with an electric pump. There are pros n cons to each.
ZMAN
Old Oct 13, 2005 | 08:20 PM
Dave89IROC's Avatar
in theory, that is the biggest thing they do to a reman pump, good luck finding parts though
Old Oct 14, 2005 | 04:12 PM
SSConceptz's Avatar
So if I find the parts would it be better to do it myself? Also someone told me I can take mine to Autozone I think and give it in as a core and get a reman for like $45
Old Oct 14, 2005 | 04:17 PM
Dave89IROC's Avatar
I wouldn't try to rebuild my own, I would just get a reman from autozone or sismilar
Old Oct 14, 2005 | 04:55 PM
sko_spo's Avatar
i had to replace my water pump 2times in three months because of that stupid weeping hole ,mine wasnt reman either it was a brand new one to boot , my pump has a lifetime warranty on it too
Old Oct 14, 2005 | 05:03 PM
pillagenburn's Avatar
could be on its way out - go ahead and get a reman from autozone ($~50 after core). Its a pretty easy swap, just drain coolant, remove lines/hoses (make sure you have rags/towels EVERYWHERE) and just unbolt the pump.
Get a razor and some (180 grit maybe?) sandpaper, scrape (with the razor) as best you can to get all the gasket material off and then sand the gasket surfaces on the pump itself and on the block. Don't let shavings get in the coolant passages, make sure you sand the surfaces down really well so no gasket material remains. Also make sure you score (scratch marks) the surfaces really well - this helps the gasket material seal a LOT better. MAKE SURE YOU USE THREAD SEALANT ON EVERY DAMN BOLT YOU USE (not loctite) - Follow the torque specs for the pump in your haynes manual (i believe around 30 lb/ft for the big ones and in a particular pattern ... I just swapped sides putting each bolt back on and tightened them in 3 seperate increments, then finally made sure they were all well tightened well). Reconnect everything, refill and bleed the coolant system then you're all done!
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
BLK1997Z28
May 7, 2015 03:01 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
pologreen97z
Dec 2, 2014 10:42 AM
