If I blow out my rear....
Old Feb 24, 2003 | 10:35 AM
95TA8280's Avatar
OK say I'm raicing and for some odd reason I blow out my rear....what will happen? Will I be able to drive home from the track (an hour...all highway)?
Old Feb 24, 2003 | 10:41 AM
Brent94Z's Avatar
Super Moderator
Depends on how bad.
It could be so bad the car won't even move or you could just damage one of the teeth and it could make a click/clunk but still be driveable. Just depends.
Old Feb 24, 2003 | 11:28 AM
IDOXLR8's Avatar
Typically you shear the teeth off the ring gear. Depending on the failure you will not be able to drive the car back home.
Old Feb 24, 2003 | 11:34 AM
RealQuick's Avatar
Re: If I blow out my rear....
Ever since the hotcam install you've been active on the board The power bug bit ya huh I worry about the same thing with my Z cuz I'll be running dr's up at NED. I'll see you up there.
Old Feb 24, 2003 | 11:39 AM
donot_4get's Avatar
I got a "complete" stock rear end sitting in my garage just in case something happen . ... you never know when you'll need one.
leo
Old Feb 24, 2003 | 11:53 AM
95TA8280's Avatar
Re: Re: If I blow out my rear....
Comeon...heads P&P, a ton of suspension work, PCMforless and a 100 shot.....power bug? Nah!!
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
