If Brass Plug From Ewp Is Leaking Can It Cause Any Damage To Whats Inside The Timing
Old Sep 9, 2006 | 11:43 PM
playa7970's Avatar
can it cause any damage to whats inside the timing cover?
Old Sep 10, 2006 | 01:03 AM
1racerdude's Avatar
Re: If Brass Plug From Ewp Is Leaking Can It Cause Any Damage To Whats Inside The Tim
No but it might soak the opti.
Old Sep 10, 2006 | 01:34 AM
2fast97z's Avatar
Re: If Brass Plug From Ewp Is Leaking Can It Cause Any Damage To Whats Inside The Timing
yes it could definately damage the opti..that constant water flow will indefinately start soaking through your opti and car will run like ****! get that fixed quick
Old Sep 10, 2006 | 11:05 AM
playa7970's Avatar
i got one problem though i cant get the crank pully off it looks like a generic balancer with three bolts holding it down plus the bolt in the middle any idea how to get it off?
Old Sep 10, 2006 | 11:07 AM
Javier97Z28's Avatar
Moderator
You need to get a gear puller, no big deal.
The bolt in the middle is for the hub, you don't need to remove that or touch it. Just the 3 5/8" bolts that hold the balancer onto the hub.
Old Sep 10, 2006 | 11:12 AM
playa7970's Avatar
well what i have is i rented crankshaft puller from discount will that work on this??
Old Sep 10, 2006 | 11:21 AM
playa7970's Avatar
and how do you take off the three bolts without moving the balancer
Old Sep 10, 2006 | 11:34 AM
anaik's Avatar
Impact wrench or wedge the damper somehow to hold it steady. If you have a damper like in the picture you can use a hub puller or do it like this;
shoebox picture
http://shbox.com/1/pull_pulley.jpg
Old Sep 10, 2006 | 11:46 AM
playa7970's Avatar
one problem is that because of the shape of the damper i cant get the claws on properly and i dont have access to a impact gun
Old Sep 10, 2006 | 12:21 PM
anaik's Avatar
Are the three tabs between the spokes on the damper threaded, they should be? Use a triangular hub puller and thread the three bolts into the tabs. I broke my damper bolts lose by tapping the ratchet with a hammer.
Jlo
Feb 3, 2015 09:41 PM
rjc1629
Jan 27, 2015 10:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Skull Leader
Aug 10, 2002 11:01 AM
